Kunena 6.4.13 Released
Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
13 years 3 months ago #143578 by webmaisterpro
Hi Kunena friends,
Well, I just tried to install latest Kunena 3.0 RC1, but installation freeze, showing the following message:
Here is my system information:
Database Version 5.1.68-cll
Database Collation utf8_general_ci
PHP Version 5.3.23
Web Server Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 2.5.11 Stable [ Ember ] 26-April-2013 14:00 GMT
Joomla! Platform Version Joomla Platform 11.4.0 Stable [ Brian Kernighan ] 03-Jan-2012 00:00 GMT
13 years 3 months ago #143583 by Matias
You have probably displaying warnings, which for some reason break the AJAX reply (a bug?). Are you able to see (by using FireBug or similar tool) what the AJAX reply looks like?
13 years 3 months ago #143600 by webmaisterpro
Matias wrote: You have probably displaying warnings, which for some reason break the AJAX reply (a bug?). Are you able to see (by using FireBug or similar tool) what the AJAX reply looks like?
I have already revert to Kunena 2, as the test was done in production website. Just a guess, that the issue might be related to CloufFlare CDN. I might try to reinstall it once more in a time with less traffic on my website.
13 years 3 months ago #143651 by Matias
We're also using CloudFlare, with no problems (this site is running K3.0). We have set up direct access to the backend without advanced caching & other settings, but the installation seems to work just fine without it.
Must be something else.
BTW: if installer fails, you could also try to visit the component as it tries to run installer again.
13 years 3 months ago #143715 by webmaisterpro
Sure, it might be something else, 2 components are not up to date, so this might be the other reason, as well as it seems that my server was showing strange behavior due to DDoS attack at the same time.
I also tried that, same error, actually not an error, just installation didn't go anywhere. I just checked other suggestion to try to install Beta first and after that RC, I will try this during the weekend and come back to report.
13 years 2 months ago #144171 by naimless
Hi Webmaisterpro - I'm having the same issue with a similar configuration (but no cloudflare) - did you manage to resolve it by any chance?
Time to create page: 0.263 seconds
